Blower motor
Sixer
4:32 PM
Lakeville,Mn
Anyone done a blower motor on 66-67 Coronet non-air? Does it require complete heater assembly removal? Thanks.
mine is ac,but the hole in the firewall is huge,so i doubt it requires box removal.just the bolts in the eng compartment.
That's just it-there is no hole in the firewall. Completely different setups. Not the typical flange mount accessed from the firewall side.
do you have a pic?i thought all the walls where the same and just filled holes with plugs.
you will have to remove the heater box from the firewall. the non a/c heater blower motor does not go through the firewall. blower motor is mounted to a metal plate that has 1 of the 3 mounting studs to the firewall.
