Hi all...I'm about to start getting brake parts together for my 68 Satellite, originally manual drums at all 4 corners...I will be upgrading to manual disc in front and staying with the rear drums for now, and I'm having trouble sorting through all the different info out there...First, do I continue using my drum dist. block and just add an adjustable prop valve for the rear line? (the kit I'm shopping includes the adj. prop valve and a disc/drum MC) Next, I don't know if I need "over" or "under" the frame front lines, the rubber hoses in front hang downward from the tabs on the frame but again that was for drums and the original lines are long gone. I would also really really appreciate any pics you could post showing your lines at the MC/block area and how they run out to the wheels..thanks again for help!!
