Brakes locking up
Osoroho
9:30 AM
Wills point tx 75169
I have a 70 Super Bee 440 4 speed the brakes will lock up for no reason that i know of it has drum brakes we replaced the master cyl no change i am stumped please help i do not have enough hair to pull any more out
Usually due to contamination. Like axle seal leaks, wheel cyl etc..
You need to pull the wheel(s) that are locking up. As said could be lining contamination or even broken/loose brake part.
Yep, more info would help. Are you driving and the brakes lock up without touching the pedal? Lightly applying the brakes and they lock up? 1 wheel, 2 wheels, all 4 wheels, fronts, rears?
[1] M/c piston not fully retracting will hold brakes on, heating them up; makes them very touchy.
[2] Brake shoes adjusted too tight, get hot, as above.
