It will not be indicated on the fender tag of a car built at the St. Louis or Windsor plant.
If it was built at the Lynch Road plant, a SG designation would be a part of the axle assemble code on the top line of the fender tag.
If you have the broadcast sheet, look on line 2, sixth code from the left. You will see a box with a heading D91. If there is the numeral 1 in the box below the heading, the car came with SG. If the box is empty, the car did not come with SG.
Thanks for the info. The build sheet says it did not come with one, but it does have one. I am almost disappointed in that it is not the original rear end, but happy at the same time that I do have a sure grip.
