FOR SALE ******* buy charger parts now ******
black68
10:31 PM
illinois
Feedback: 1 / 0 / 0
******* buy charger parts ******
-Wheel set - 80% + tread left 5x4.5 lug pattern 255/60R15 Rears 235/60R15 Fronts - 500
-used original splash guards ( front corners under frame rails)
-stock used 727- 8.75 drive shaft
-vacuum canister ( for headlight doors )
-Original vacuum hoses ( for head light doors ) complete
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-front drum spindles
-stock sway bar
-lower control arms
-stock intake manifold - 65
-stock heads - 85
-stock 383 valve covers - 25
-used 383 headers ( needs media blasting, rusty ) - 50
-used fan off a 383 - 15
-steering gear with pitman arm - 100
-Saginaw power steering pump - 40
-steering wheel horn ring - 25
-steering column- column shift- ( with aftermarket wheel) - 150
-rear window glass ( used ) - 100
-used alternator - 25
-lower a/c vents ( PAIR ) - 40
-dash a/c selector - 100
-radio speaker knob and plate - 50
-OEM used brake booster - 30
-8.75 complete rear axle - 3.23 ratio - 250
-original rear leaf springs - 100 ( set)
-used 5x4.5 bolt pattern vector style wheel set ( widened lug holes , wide rears) - 400
-sun visor set ( some stitching coming loose) - 35
-fenders ( driver & pass ) spots need repair 150 ( each )
-glove box door ( needs dye job) - 75
-used original parking lens set - 25
-68 chrome ribbed console top - 3 piece set - ( good amount of pitting ) - 125
-inner windshield trim to headliner - 65
-dome light - 30
-rear bumper ( great core, needs refinishing ) - 150
-68 charger grille support - 100
-upper quarter window pad set ( needs refinishing ) - 200 (set)
-Original chrome auto console shifter - 50
-Auto shifter console top w/ indicator - 60
-68' charger torsion bars ( set ) - 50
Some items pictured here :
https://www.flickr.com/photos/93359881@N06/sets/72157638378349525/
-auto shifter knob
Power brake car ? Need the bellcrank assembly under the dash ??
How much for the drive shaft shipped to 89701
Also interested in the rear-end if shipping is feasible...
-stock used 727- 8.75 drive shaft - ***SOLD***
-vacuum canister ( for headlight doors ) - ***SOLD***
-Original vacuum hoses ( for head light doors ) complete - ***SOLD***
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-stock sway bar
-lower control arms
-stock heads - 85
-dome light - 30
-auto shifter knob
https://www.flickr.com/photos/933598...7638378349525/
Parting out complete K member front suspension for 68' charger
Jeff from Nevada, 89701 - on the rear end, torsion bars, and shipping.
Any luck on the shipping of the '8.75 complete rear axle - 3.23 ratio - 250' ?
I might pop on the torsion bars too, since it could ship with the rear end...
I got the driveline, but didn't put it on yet... thanks!
Jeff-
  • -Wheel set - 80% + tread left 5x4.5 lug pattern 255/60R15 Rears 235/60R15 Fronts - 500
    -Stock K - member
    -Steering rods
    -upper A - arms
    -idler arm
    -stock sway bar
    -lower control arms
    -stock heads - 85
    -8.75 complete rear axle - 3.23 ratio - 250 ***SOLD***
    -dome light - 30
    -auto shifter knob
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-stock sway bar
-lower control arms
-stock heads - 85
-dash a/c selector - 100 *** SOLD ***
-OEM used brake booster - 30 ***SOLD***
-dome light - 30
-auto shifter knob
Brake pedal knuckle - ***SOLD***
*** NEW ADDITIONS ***
Two driver side mirrors ( sold separate ) - some bubbling of the chrome - $50
Steering column w/ steering wheel - $ 150
Valve cover breather - $ 15
Used arm rest set - needs refinishing - $40
-Original heater core radiator - 10
- original blower motor - 25 ( tested and works )
You got a pic of the a/c selector and a shipped price to 85014. Thanks Ed
please look at the last couple posts, they are updated. the selector has been sold, im sorry
a bunch of original parts still for sale, please look at the last listing for updated list
