C Body 11/16 Tie Rods on a B Body
hunt2elk
11:05 PM
WI
I am going to rebuild the front suspension on my 69 RR. Noticed on PST's site that an option is to use C body tie rods with the bigger shaft and would then go with solid adjuster as well. Anybody done this upgrade? Is it worth it?
I have not done that swap, but I have heard of it. As long as you can adjust the total length to match a b-body & the tie rod ends bolt up, why not?
Total bolt on and since it’s 11/16 vs 9/16, you get the flex you would get with the smaller set up. You’ll need 2 inners, 2 outers, and 2 sleeves then your in business. Hell, I even put them on A body’s.
Can't tell you if it's worth it...I used them because they look cool. Just being honest.
Thanks guys, I am going the bigger is better and cooler route.
