Cast Aluminum Mopar Performance Valve Covers and Crankcase Evacuation
ykf7b0
11:31 PM
Tennessee
Do any of you use Mopar Performance cast aluminum valve covers along with a Moroso crankcase evacuation system? If so, where did you get the grommets for the push in breathers ? My internet searches lead me nowhere. Thanks! Greg
You will find that there are 2 different types.One for stamped steel and the ones for the thicker aluminum.Check with Mancini or other suppliers as Mopar Performance had a installation kit with longer bolts and grommets for the aluminum covers.
Thanks! I am hoping to find some that would convert the oil fill cap hole to push in breather type. These would need to be somewhat wider at the top to cover the oil fill cap slots.
Try Moroso screw-in breathers, with thin, metal washers on both sides of the cover[if the hole is still over-size].
https://www.summitracing.com/parts/...se1-_-moroso&gclid=CJLV4P6Ij88CFQUEaQodTOcNWA
Mancini had exactly what I was looking for regarding the grommets. Thanks Darter6!!!
