CAVIET EMPTOR eBay listing
RJRENTON
2:41 PM
South Shores area of Decatur, Illinois
Fyi..
I was looking on eBay for AFB carb parts and found the sbove listing. Here is what I sent to the lister.
Re your listing..... sent a message about mopar carter afb 1966 Hemi carb. 4137S J5 manual California #253000659083
Your listing is not for a Hemi car, but for a 1966 440 cubic inch engine. All Hemi primary carbs (rear position on engine) had hot air chokes, only in 1971 engines (last year of ptoduction) used a MANUAL cable operated choke. The secondary carb (front carb on engine) did not have a choke at all. You may have taken it off your Hemi but Mopar did not origionally install it on a Hemi engine. In addition, the other give away is the mounting base drilling. Origional Hemi cars did not use dual base drilling patterns. Another give away is the choke vacuum pulloff diaphragm assembly. Hemi engines did not use a vacuum pulloff diaphragm assembly.
The first pix shows the bottom view of an AVS carb and the idle mixture screws in the mounting flange not like an AFB carb, where they go in at an angle. Perhaps you may want to correct your listing or adjust your price to reflect the change. Just thought you might like to know.
If you went to the listing, this person was selling the carb for $1450.00. What a deal..... I wonder how many people bid on the listing. eBay strikes sgain....or definitely CAVIET EMPTOR.
BOB RENTON
Link? Btw, stuff like this from Ebay, CL and other ad sources goes to the General Forum. Thanks
See crap like that all the time, given up most of the time contacting seller. If you don't know what a Hemi carb looks like you better learn before pissing that kind of money away. Bought hemi carbs at swap meets before I learned date codes. Was looking for 66 Hemi carbs for my car. Gave those wrong date coded carbs gave me the money to buy the right (sorta)carbs. Really want K5 dated carbs but have an M5 and L5 carbs for a Feb assembled engine.
https://www.ebay.com/itm/mopar-cart...659083?hash=item3ae803b08b:g:GqYAAOSw~rpZSDvi
Just for giggles, i looked up a listing in another thread about KH rotors. Sent me to an ebey listing. For curiosoty sake i clicked on a conversion disc brake set for 62-74 mopars. To my surprise, they fit more than fourteen hundred vehicles, starting with 2010 audis (listing of cars it fit was alphabetical)
I have never bought ANYTHING on ebay, doubt i ever will.
I've learned that usually trying to help folks like that is pointless. Folks that really want to sell a Hemi carb are on their game, and ones that post ads like that usually don't give a crap.
When buying anything from Ebay, you need to know your numbers.
There are so much items for sale, not only Mopar related, that are not right, false description or what ever.
Some may, as expected, sale something that supposed to be "rare" and ask sky-high prices for an object that is NOT that part.
Be aware when buying from Ebay!
Fyi..
BOB RENTON
Just an FYI here in addition to Cranky's suggestion.
It's actually spelt "caveat emptor" ....if you're going to quote Latin you need to get it right, otherwise it looks stupid.
I appreciate your comment.....I did spell check the phrase and it said it was OK...i'll go back and correct the spell check....
Best regards,
BOB RENTON
Well....
SORRY.....did not know the appropriate catagory....since it was a carb related subject, I stuck it there. The #253000659083 was the eBay listing number.
BOB RENTON
Looks like Fran posted the link? When you copy and paste the link, it just makes it easier for others to find it. Why are you engineer types so hard to get along with!!? :D :D :poke:
Thanks Kern I mean KIWI:poke::lol:
