SOLD Chrysler 361 engine and push button A727 transmission
sdgodwin
6:24 PM
Maryland
odometer reading on car when removed was 78000 + miles. Engine runs and trans shifts and turns. Two barrel. Block: cast May 31, 1962. Includes casting number 2205712-4 N.L.S. Engine assembled in 1964.
Price: $500.00 - Negotiable!
location 20678
Engine Transmission.jpe
I do appreciate the offer.
Did you know how good the engine is? as to compression, or is it an engine you have run and does not smoke or knock?
We are just at the starting point of building a shop here, wife is in process of getting catarac surgery, and then at end of Oct . trip from Tx here to Mo. for daughters wedding (1600 mi)!
Can you get an est. of freight to 77371? How quick do you need it gone?
That is a very generous offer for sure!
will get est. the engine run with no knock or smoke. when i took it out the distributor was messed up. i did first aid and fuel and it started right up..
because of its size its around $500.00 try at your end. my location is Prince Frederick md 20678the engine is just shy of 6 feet long and 3 feet tall and 3 feet wide. It is mounted to a frame that will support engine (by the motor mounts) and it weighs approx. 850 pounds dry. I will drain everything except torque converter.
I appreciate the offer but I will just have to pass. Just way too much on my plate, wife is getting catarac surgery, shop is in beginning stage of going in, no place for this engine right now, K frames to change out, the list gets long.
