- 6:55 PM
- Feb 29, 2020
- Heart of Dixie.....
Guys, I have been collecting parts for several years now to return my OEM 73 four speed back to a four speed. A PO in the past had swapped the whole drive train over to an automatic, so , I ve had to find it all. The bell housing is a Mopar part I found at a swap meet. Seller said it came from a hemi, it was in good condition. The fork is brand new Chrysler said to be correct for my 73. Clutch is a stock diaphragm unit for a 440. I had the release bearing clipped onto the fork prior to installing the four speed but had trouble getting the tranny in that last half inch. That suckers heavy trying to put in by yourself to twist and turn and push. So , I pulled the fork out thinking maybe it could be binding. No help, and had to back off the pressure plate bolts to let the clutch disc move and it all slipped right in. So, now have the bell housing up tight to the block and tranny up tight to the bell housing but now cannot get the fork back in place. With the release bearing hard up against the diaphragm fingers, it still needs to move forward more than a 1/4 inch to get the fork ears to clip in behind the release bearing tabs. Seems to me this would cause the bearing to be always spinning. Isn t that bearing only to touch lightly or none at all when no pedal pressure is applied . I m thinking I got some mismatched parts but not sure what. The fork appears to be the correct length for the new linkage I have. Maybe you can tell from the photo....thanks.....
