Console wiring question
L&LClassics
8:34 PM
Arlington, Texas
I'm working on a 68 gtx auto with console. My wiring diagram tells me to connect the console harness to the console wiring on instrument panel. I have looked under the dash but can't find anything to plug the console harness into. I guess I'm not sure what I'm looking for. Can anyone help with this issue?
should be a free plug behind the drivers kick panel Yellow and pink wires
I should add that on mine, there is an intermediary harness that plugs the console harness to the dash harness. I can send you photos if you like.
PM me
If you don't have, consult the factory manual, which you can download free from MyMopar
http://www.mymopar.com/index.php?pid=31
Also go to the wiring section
http://www.mymopar.com/index.php?pid=27
and download 68 Ply etc etc "full set" which is just the diagrams just for B body, out of the shop manual, this file
http://www.mymopar.com/downloads/1968/68BelvedereGTXSatelliteRoadRunneFull.pdf
Some models / years required a "jumper harness" between the instrument connections and the console. One connector (floor shift automatic?) should be the "half moon" shaped one for the reverse lights, with a white and violet wire
Start with page 7.........of the file posted above and then page 3, "accessory wiring" and look for the 4 pin connector towards top right, see if that is what you are looking for. should be pink, white, violet, and orange
