eagleone1983
Hey Guys I'm having a fluid contamination issue. So I noticed a few weeks ago my car was pulling to the right upon braking, to the point that it would change lanes if I didn't fight it. Scared the shiz out of me the first time it happened. So I checked my master cylinder and the forward section (reservoir closest to front of car) was milky looking. Rear reservoir was nice and clear purple (DOT 5). So I cleaned out the master cylinder and bled everything until it ran clear purple again, problem was solved drove it for about 30 miles or so. The car sat for about a week or so and I took it out again, same issue pulled to the right just as bad as before. So I pop open the master cylinder and the forward reservoir is milky again, what gives? This is the first summer I've had this issue. All brake lines hard and soft, drum brake components front and rear, and wheel cylinders were replaced in 2012 when the car was finished with it's resto. The booster is new 2012, the only thing I didn't replace was the master cylinder but it's not an original and was replaced sometime by the previous owner of the car but worked fine so I cleaned it up and kept it. Could the master cylinder be the issue? I don't see any leaking anywhere.
