Correct Distributor?
70b5bluerunner
6:17 AM
N. Central PA
My brother bought a single point distributor off ebay that is supposed to be correct for his 69 Coronet R/T 440 automatic trans. The tag no. is 2875764. Is this the correct distributor for his car? Also, I see that you can buy a refurbished single point distributor from Rockauto and send them your core. Would this be a wise thing to do? Is there a difference between the HO 440 distributor and the base one? Any help would really be appreciated.
The 2875764 distributor that your brother bought is for the base 350HP engine for a '69 440. The 375HP HO engine distributor is part number 2875758 according to my book. The distributors are a little different as far as the advance timing is concerned but not by a lot. I think that the advance comes on a little sooner on the 758 distributor. You could probably use either distributor with a little tweaking if matching numbers isn't important. I can tell you for sure that if you buy one from Rockauto or any chain parts store you will get whatever refurbished distributor they have on the shelf for a '69 dodge 440 without any regard to the factory part number. Hope this helps.
If you want correct numbers, you can buy reproduction part number tags. I picked one up not long ago, but cant for the life of me remember who I got it from. Do a search and they will pop up. I also picked up a single point on E bay for my 71 R/T 440. it was not the correct number distributor, but I send my distributors to Advanced distributors in Minnesota. He will reasonably tune it up specifically for your application and you will be farther ahead then buying an unknown rebuilt unit.
Thanks for the help. We are already in the process of getting the tag and contacting the distributor people.
