kenw383
New Member
I'm installing a CPP power booster/master cylinder in my 66 Satellite. The clevis arm from the booster that bolts to the brake pedal arm is thinner than the manual master cylinder arm. Has anyone run into this issue and what is the best fix? I could shim it with washers on either side of the clevis arm to center it and remove any play. Also, I haven't bled anything yet but the brake pedal hangs down about a 1/4 inch. Will it come up to the proper height when everything is reassembled and bled?
