WTB Cruise control
Mark Pifer
2:19 AM
Venice, Florida
Feedback: +0 / =0 / -0
Hi, I have a 1973 challenger rallye I want to put cruise control in.
Does anyone have all the parts.
There is the:
- Servo
- Speed control stalk with it’s wiring harness.
- Upper cable that connects between the servo and carburetor linkage
- lower cable between the transmission and speedometer.
- 3 pole brake switch with wire harness.
- linkage from end of servo cable to throttle on carburetor.
- wiring harness from servo to speed control stalk harness.
- bracket that attaches to brake booster which the cable from the servo to the throttle linkage secures to.
Let me know thank you.
Mark
Upload Photos
There is a difference between the E body stalk and the b and c body stalks. One difference can be how it mounts to the steering column. Another is the angles coming off the steering column mount are different. Also, the length of the stalks. The E body stalk is longer. The attached photos you can see the differences a little better. There is a slight angle difference, and the E body lever is about 1.5 inches longer than the B body.
