Dana 60 Powr-lok questions
Chuckcharger
4:19 PM
Arizona
1. Would a Powr-lok from a 8 3/4 work in a dana60?
2. Is it the same Powr-lok carrier for 5:13 gears as 3:54?
Completely different carriers. I believe 4.56 and numerically higher share carriers in a dana 60. They probably make a ring gear shim to put 4.88s on a 3.54.
They make a shim if you want to run 4.56 or lower gears. You can buy a housing for lower gears and put the guts of the 3.54 housing in the new housing.
