Dash clock
66 convert
2:27 PM
Cherry valley il.
I am looking for a dash clock for my 66 coronet convertible.Anyone know where one can be found?My car has the clock delete panel installed.
Good luck finding one, If you find and install, make sure you put that insulation tape piece on the clock. I used the one from the delete that I removed. The AMP gauge panel above it is hot and the clock can short on it. When you install move the time adjuster around and watch for sparks with the key on. Good luck
