Dash Gauge Regulator and Turn Signal Switch - I have part numbers for replacements
EvelBist
6:11 AM
Arizona
I'm working on a '69. I don't know for sure if these parts work with all gens but they do work with my 2nd gen.
The STANDARD MOTOR PRODUCTS VRC601 is an OEM style mechanical points style replacement for the 3 prong mechanical dash regulator plugged into the back of the gauges circuit board.
OE PRO SM106 is an exact replacement for the turn signal switch on NON-TILT columns.
Sorry if you already know this. Hope it helps. Rob
BTW: Both are available at RockAuto
I don't see anywhere where it states that this is a solid state regulator instead of a points style....enlighten me please
Corrected the regulator type to points style, not solid state. Rob
BTW:
I adjusted my original gauges using the techniques shown in this thread:
http://www.dodgecharger.com/forum/index.php?topic=37999.0
I used a solid state 5V supply. But I'm using one of the VRC 601 units in my dash. The gauges dont respond the same when using the VRC 601. So I had to readjust the gauges using the VRC 601. They now are fine and correct.
So make sure you use the same kind of regulator you'll use in the dash when you adjust the gauges. Rob
