Dash light/ Brake System
texasbird
10:15 AM
Austin,Texas
I'm rewiring my 70 RR and have a Waring Light on Driverside that light up when I set the parking brake. If the fluid in the brake system should get low will this light come on as part of the waring system?. I've on seen it on when the parking brake is set.
The light is showing age would anyone know a source to get a replacement?
Thanks for your time and attention.
i just fixed mine on my 70 RR. yes the light will come on if the fluid is low....when the parking brake is set.....and if the seals in the master cylinder causes the pedal to go to the floor.(even if the fluid is full). as far as replacement goes....i just replaced the bulb.....im not sure of your total situation but if it goes on when the parking brake is set you should be good to go! (beep-beep)
Performance graphics has what your looking for also. Good luck with your project.
