- 12:44 PM
- Apr 13, 2012
- Granite Bay CA
Please forgive me if this topic is deemed inappropriate for the forum...
The wife and I have a 2003 Honda CRV that we have had since it was new. We keep it to haul our dogs to the vet and out to play. It has been great and required very few repairs in the 20 years, 130,000 miles.
The problem....Yesterday it was running rough and it lit up the engine light. My code reader showed a DTC of cylinder 3 misfire.
It has sat since New Years eve with the same gas in it since before Christmas.
Today I pulled the coil pack from #3 and swapped it with #1.
Then the code read cyl # 1 misfire. Score...that must mean the coil pack is bad so I bought ONE....$80 retail for ONE.
Back home, I swapped the new coil plug into #1 and started it up. Now I got a code for cyl #3 misfire again. The spark plug for cyl 3 looked okay but I don't recall when I changed the spark plugs. Maybe I should just put in a new set. A closer look at the code reader showed THREE codes....cyl 1 misfire, cyl 3 misfire and random misfire. It does feel like it is missing a bit but not 2 cylinders. Maybe they are intermittent?
I swapped coil packs all around but keep getting the same 3 codes.
I wanted to pull some gas from the tank to get a look at it....cloudy means water in the fuel. The system is sealed but we have had a lot of rain lately and the Honda sits outside most of the time. I went out to drive it to use up some gas but the damned thing barely used any fuel. You'd expect a misfire or two would really cut down on the fuel economy but that wasn't the case. It is down on power though and I can feel the engine lagging.
The fuel filler neck must have some baffle in it because I couldn't get the fuel hose to go in very far. I guess I'll have to just run the gas out and then pour in fresh gas to see if the problem is fuel related. The air filter is fairly new and still clean.
We have mice and rats crawling around this rural area so I looked at the wiring underhood. Nothing looked bad from what I could see but it has happened before. I had to solder in wires for the transmission solenoids a few years ago.
Before I take it to a shop....do you have any ideas on what else I should look for to fix this thing? It seems like I'm forgetting something.
