Disc Brake Kit
dodge68charger
7:54 AM
Washington
Does Any Company Offer a Direct Bolt On Front Disc Brake Conversion For a Drum Brake Car?
Looking For Something Bolt On, No Guess Work With Linkages And A Booster/Master.
Sure, several companies make them. Wilwood, SSBC, etc.
Avail yourself of the SEARCH box feature in the upper right of this site and you'll find
literally dozens of threads on the subject.
I used the SSBC kit. It was a direct bolt on conversion for a manual front drum car.
I will say that I was not happy with the m/c that comes with the kit. Too much leg pressure to stop the car. I changed to a 15/16" m/c and stopping is a lot better.
Dr Diff pretty much plug and play
Another vote for Cass at Dr.Diff. Mine wasn't exactly direct bolt on. I had to enlarge the hole in my firewall where the booster goes but other than that it was fairly straight forward. Been running it now for two years, no issues.
Just got a power disc brake conversion kit from Pirate Jack. Came with everything except new lower ball joints. They sent the wrong booster and firewall plate, but I should have the correct parts tomorrow, which they sent 2 day air UPS.
