disc brake swap parts needed
68gtx
9:58 PM
terrace b.c.
gonna do a front disc brake swap on my 68 gtx, got spindles off of a 70's dart, but am lookiing for caliper adapter brackets so i can use the 11.75 inch rotors? anyone have any?
I just did this swap on my 69 RR and used parts from a 78 Magnum donor. I swapped the calipers/brackets side to side to clear my front swaybar.
I don't have spare brackets but will ask around for ya!
well using this info http://www.moparaction.com/Tech/archive/disc-main.html , the way i read it is i can use the mid 70's spindles and disquard the caliper brackets i have for the 10 7/8 rotors and with the bigger brackets use the bigger rotors?
You are correct- The mid seventies a body spindles will accept 11.75" rotors and caliper brackets from mid to late seventies B bodies.
