FOR SALE Dodge Plymouth 440 Motors
65satelliteman
9:12 PM
Tawas City Michigan
Feedback: 18 / 0 / 0
Hi Guys & Gals: Since my health won't let me restore anymore cars, I have 3 -440 motors to sell, the details are listed below. I'm located in Tawas City, MI.
1969 Dodge Plymouth Motor Engine
This Dodge or Plymouth Motor is out of a 1969 Chrysler 300 with a dual snorkel air cleaner & 440 TNT pie tin. Stamping pad shows E440, with a build date of 03/28/69. Should be a good date coded motor for the 1969 Road Runners, GTX's, Super Bee's, Coronet RT, Fury GT, Dart GSS and Cuda S440. This motor is complete from air cleaner to oil pan and includes the power steering pump. It was a running motor when pulled many years ago and was covered up and stored with oil in the cylinders. I'm too old to think of turning a motor over by hand, so I can't tell you if it froze up or not, but by this assuming it needs to be rebuilt. $750.00
Dodge Plymouth 440 Motor Engine
This is a steel crank 440 motor out of a 1973 Dodge Truck and has the thinker webbing than the earlier ones The stamping pad reads; J440T and would be a great engine to build up high horse power for any Dodge or Plymouth Car. This engine is complete from air cleaner to oil pan and includes the power steering pump. This was a running motor when pulled and has been covered and stored with oil in the cylinders. I'm too old to try to turn an engine by hand, so I can’t tell you if it might be froze up or not. So if you are thinking of buying this motor, assume it needs to be rebuilt. $400.00
1967 Dodge Plymouth Motor Engine
This 440 Motor has an engine stamping pad #B440 with an assembly date of 08/03/1966. That makes it as going into a the very first 1967 Cars, so this should be a good number for the earliest built 1967 Plymouth GTX & 1967 Dodge Coronet RT. This was a running motor when pulled and has been stored with oil in the cylinders. I'm too old to try to turn an engine by hand, so I can't tell you if it might be froze up or not. So if you are thinking of buying this motor, assume it needs to be rebuilt. $650.
If you want any of these motors - I can have them hanging on a cherry picker on a cement driveway, just bring your trailer.
I'd like to have that 69 setup
