Dodge Vs Plymouth Window Clips?
dodge68charger
2:26 AM
Washington
Just Wondering If Theres a Difference Between The Window Clips That Hold The Stainless Molding Around The Front And Rear Windows on The Dodges and Plymouths?
Front the same. Rear may share some clips. Only reason I say this is the differences between models. Charger,Coronet,Satellite models.
I believe the back window on 68-70 chargers trim clips are different then others.
All I can say is save as many originals as you can and if short at least use those at the end and corner of each piece of trim. I had pretty good luck with front trim clips. None of the rear trim clips were worth a damn and needed modification with a punch hit to give them a "catch" point.
