Ahh see i learned something there... I knew the switch he posted was the same as the ones up to atleast 69.Wrong switch. That's an early switch. Not sure when they went to the two wire door switches, but I'm thinking 70-71.
it is called a splice in the auto repair world. knowing the circuit as a working tech under stand that further up the wire will be the second / splice wire. the door switch is a ground for the dome and interior lighting. witch is the yellow wire the second yellow with a tracer color is for the other side so the dome and other lights have power all the time when you open the door it grounds the circuit and boom the lights come on.the pink is the power to all interior lights
Weird, I always have known just 71s were 3 pins. Maybe earliers 72s too? I have found on all 72s I have "worked" being 2 prongs on driver side.'72 would have a 3-pin switch on the driver's door and a two pin switch on the passenger side.
mmmmm... weird
