Electrical advice needed
1969superbee
11:01 AM
Vidalia,Georgia
I am switching over to electronic ignition on a 440 six pack motor. I have purchased a 440 source distributor and am going to purchase a rev-n-ater as soon as they come off back order. What voltage regulator and alternator ( single or dual field ) do I need? Do I need to still use a resistor?
Thanks in advance
The alternator is up to you - but make sure the regulator matches the alternator. Yes, you still need a ballast resistor with the Rev-N-Nator unit - stock wiring is how they work. ;)
I bought all new M&H wiring harnesses to swap it over to electronic. What voltage regulator do I need? Can I use a stock one or do I need one for electronic ignition?
