dcmason69
My question goes out only to anyone that has installed the Energy Suspension sway bar bracket kit 5.5135 on their 68-69 charger or coronet and kept the original bar.
When this kit is installed does the sway bar sit in its origanal position? meaning does the hump on the bar go upward as factory over the brace from radiator support to K member or does it have to be repositioned to have the hump go downward under brace?
I am needing to know do the new brackets sit further away from K member (lower)
making it necessary to put bar in upside down for clearance from brace?
Hope this makes sense, I saw one on a 68 charger and the bar was upside down
using the Energy Susp. kit just did not look right at all, I want to use my original bar do not want to buy another style sway bar. And want to retain brace.
Thank You
dcmason69
Thank You
dcmason69
