Engine dies sometimes
joseph p.
5:05 PM
walnut creek ca
hello to all.i have 69 satty 383 4bbl,727 auto.im thinking because I didn't warm her up enough, about 5 minutes ,but this happened a few times ,engine cuts off like I ran out of Fuel, and i pumped the gas peddle ,then boom she backed fired,I pulled over after trying to start her after 2 tries and I just let her idle for 10 minutes,then she ran fine, Also I haven't drove her in 3 weeks,any Mopar teck suggestions appreciated ,oh I also have electronic ignition .
Description sounds like maybe fuel delivery problem? Check simple stuff like making sure the gas tank vents, the fuel lines are not dried out and cracked at the gas tank, and such. Check Fuel pressure at the carb ("t" fitting and vacuum/pressure gauge?)
I am thinking the backfire might be from too lean air/fuel condition?
When first starting it cold, check the position of your choke. Assuming you're using a stock setup, is the pulloff opening it too far? Is it opening fully too quickly? Both can create a temporary lean condition as previously mentioned.
Yes yes, what happened was, I upon starting accidentally hit the pedal when car was high revving ,I always wait for the kick down from carb when warmed,,,thanks so much,, also my coil reading was 8 ish,little liw, gonna replace coil sldo thanks, and have a wonderful 4th
Depending on your coil position, make sure you get the right one. Factory location put the coil laying down and oil filled coils are meant to stand up. If its laying down I recommend an epoxy filled coil.
I'll just add,,, go through all your grounds, good clean metal on metal contact. make sure the ignition box is tight and grounded real good at the firewall along with the VR
Thank-you !! it was loud and my hearing suffered as much as the 2 AC/DC Concerts I attended..
not to mention 34 years of Oval track racing !!!
