eagleone1983
I'm looking to buy a new engine harness but I'm not entirely sure what I should buy but I need to do it quick before Year one's New Year's special ends. I have a '69 RR currently with an upgraded mopar electronic ignition system in it but it's old. The Chrysler electronic distributor needs replaced that I have, it has a 4 pin ballast resistor, Standard brand volt regulator, and a Chrysler 5 pin ECU (I can't read some of the part number but what I can read... 874020), and the alternator is p/n 4091424 I'm guessing a 70's or later one. So my question is what should I upgrade to? Should I just go with the Chrysler Elec ignition or would something like MSD or Mallory work better for me. My engine is a 383 .030" over with a hot cam, stealth heads, roller rockers, headers, intake, etc. Also what harness should I get from Year one, the standard points harness or the one that is already modded? I ask because yearone states that if you are going with an aftermarket elec ignition (ie MSD or equiv) you'd be better off started with the points harness. Thanks for any of the help.
