SOLD Engine mount bracket, Pass. side, B-body, SB, not spool
67Charger
12:17 AM
Erda, UT
I'm doing a 5.9L Magnum swap in my /6 Challenger and need the passenger side engine mount bracket that fits a B/E smallblock on a 68 B-body K-frame. Something like '67-'72 should all be the same. I have a '72 340/360 drivers side mount, which is the harder one to get since it is narrower than the more common 318 version.
The passenger side is supposed to be the same between 318-340-360.
Is it like this one? (see pic) Removed from a 1968 B Body. I don't have it anymore, it went with the sale of the motor. Just thought I'd throw on here for reference.
I have a set from a 69 318 but they aren't shaped the same on both sides and I didn't mark them when I removed them. one looks like that one pictured and one has a slight curve on the side. I will post pics this evening if you haven't found anything yet.
The straight one is passenger side, the curved side one is drivers. 318 will have 1/4" less curve than the 340/360 mounts.
