verdelaw
I have a basically stock 68 Charger R/T with a tic toc tach.
After kicking around FBBO reading about tach updating/replacing, it seems that most people find that the original tach is, at best, sloppy and mildly inaccurate. Mine is just plain not working (none of the gauges are, except an amp meter); it seems like the most common fix is simply the cable. I have zero experience with gauges, their inner workings, or fixing them. Right now I don't much care about originality, but I do care about cost and I just want to get on the road and know what RPMs I'm at.
Should I just fix the original tach (this seems like the cheapest/easiest)? If so, should I start with the cable? If that doesn't do it, what then?
Should I just get an aftermarket? If so, which one?
Thanks in advance for any help/advice/opinions :hello2:
