FOR SALE For Slae/Trade-68 Cuda project
73SwingerDart
5:04 PM
Tulsa, OK
Feedback: +0 / =0 / -0
For Sale/Trade-68 Cuda project
Hey guys new to this site but have been a member over at FABO for a while.
Im gauging interest in my 68 Cuda project before I go any further with it. I have been spending tons of cash buying and gathering all the parts. I have about $6500 in it so far. I would like to see if there is any interest for trading or a sale. I really like the 71 and 72 satellite's, RR and Chargers.
340 motor has just been rebuilt to stock other than a Mopar cam. Engine is on stand and ready for paint. New starter, gasket set, high volume oil pump, everything new because I have started with nothing! Engine bay is prepped and painted already. Brand new polished Edelbrock carb, Mopar Performance valve covers, new battery tray, new battery, Radiator was taken to shop cleaned and painted, all new belts hoses and a new engine compartment and forward light wire harness.
Front end is fresh with disc brakes installed and painted. New master cylinder and lines.
Rear end is a 8 1/4 with 355 sure grip. Transmission is a fresh rebuilt never ran A904. I have tons of new parts for this. I am missing the drive shaft but thats about it. Was planning on measuring once everything is installed.
Interior is in pretty good shape. I have new door panel set from Classic Industries in box. New windsheild installed and upper dash was painted while glass was out.
Would also consider including my Duster for the right car. Duster value around $8000.
Car is located in Tulsa Oklahoma area.
Thanks,
Todd
Post approved and good luck. Please head over to the welcome wagon and introduce yourself and hang around
Update....installed high volume oil pump with new pick up tube, installed oil pan, timimg cover and new water pump. Getting ready to spin engine on stand and paint before I install polished intake and polished carb/valve cover on.
Motor will be in soon paired to the new transmission with new factory high stall torque convertor!
Anyone interested?
20140914_111113_resized.jpg20140914_113454_resized.jpg20140914_202602_resized.jpg20140914_185505_resized.jpgUPDATE/PROGRESS
Finally had a chance to work on final assembly of 340 motor for CUDA. Looking really good! Still for sale and would consider seperating if I have to...will sell 71 340 seperatly from 68 Cuda body before I put on new tranny and torque convertor and I stab it. $4000 for motor and tranny and $3000 for clear titled and up to date tagged Cuda roller!
I have a 71 road runner that I have listed on bbodies look it up I would be willing to do some trading
Around rear window and truck look good for rust. Trunk floor has surface rust but no holes. Needs sanded down and painted. Only rust in hole car is drivers floor pan.
Getting closer to installing the motor and tranny. Installed rear wheel cylinders so I could blled new brakes. Broken air bleeder. Found a transmission crossmemer and driveshaft, installed new wireharness. Found out my new torque converter wont work so I ordered another new from Hughes. Crank shaft is a 340 forged for 4 speed and crank recess is 1 1/2 instead of 1 7/8.
Almost running....MOTIVATED SELLER!!!!!
20141031_141934_resized.jpg20141102_140227_resized.jpg20141102_164259_resized.jpg20141031_141934_resized.jpg20141102_140227_resized.jpg20141102_164259_resized.jpgUpdate...
Got the motor and tranny in today....Finally!
Transmission crossmember and drive shaft installed also.
Got the new wire harness installed with dielectrod grease on all elecrtical fittings.
New Schumacher 340 motor mounts worked like a charm!
Had to order another torque convertor from Hughes and it fit like it was supposed to.
New starter, new distributer, new altenator, new ECU, new voltage regulator, new plugs and wires, new sending units (oil and temp), new battery, new headers, 4 new shocks installed, new master cylinder and lines...ALL NEW!
Somebody needs this CUDA!
