Front Turn Signal Housing 68 Belvedere
harann1023
8:31 AM
Buffalo, New York
I am in the middle of my restoration. Recently bead blasted my front turn signal housings (They had some surface rust). I epoxy primed them. Sprayed the exterior of the housings black. I believe the inside originally had some type of silver reflective paint. Anyone know how or what I can use to duplicate that?
I believe you can paint them bright white or if you need the silver color maybe that chrome paint will work. Just clean the surface with soap to remove all organics and bead blast dust.
Like Meep mentioned, I use a chrome paint inside housings. Use a higher temp paint as well.
