rev.ronnie
Been having what I thought was a vapor lock issue on my Charger 440-6. I installed a electric pump in the rear and noticed recently that the pressure was low. When I unplugged the pump, it went to zero.
I pulled the pump tonight and the fuel pump rod is worn to level with the block. I put my scope up there and the lobe seems fair, but I'm not taking any chances. I removed the check valves from my Hemi pump on the engine and installed a 7psi non-regulated pump in the rear. I removed the regulator as well and blocked off the vapor line, dead-heading the fuel at the carbs.
What the hell...this engine has less than 2000 miles on it. Glad it was mine anyway, instead of a customer piece.
So much for a brand new Comp cam..
Anyone have any similar issues?
