Fuel System Questions
BigBear440
12:26 PM
McHenry, Illinois
Starting to replace fuel system on my 68 Coronet RT and have a couple of questions. The engine in the car is a HP 440 out of a 69 - Shouldn't the fuel lines be 3/8"? Would it be worthwhile to make them 1/2 inch? Planning on replacing the tank, sending unit, straps, pad, filters etc. Based on your experiences, I would appreciate your recommendations.
Thanks!
BigBear440
:edgy:
1/2" wouldn't be necessary - you won't be needing the ability to move that much fuel with a 440 (unless it's a really radical, high HP motor). Factory 440 cars had a 3/8" feed with a 1/4" vapor/return line which worked well. I'd recommend sticking with that.
Six pack cars came from the factory with a 3/8". Why would you need anything more?
When all the fuel in a 1/2" line has to fill two carb bowls that have a seat orifice diameter of less that 1/8" what's the point? 3/8" is plenty and I bet even 5/16's will be fine.
