patrick66
Took the '66 Coronet out for a spin a few days ago. The weather was far too nice not to take it out. Started right up, drove for about three miles at 45mph, then entered the freeway. At about 2,800 RPM, the car was cutting out, like it was running low on gas. Since I was five miles from an exit with fuel, I babied the car until I exited. It did stutter a few more times until I got to the pump. Filled it up with mid-grade (89 here) 100% gas. Checked the plug wires, fluids, fuel line and normal checks. Only took eight gallons to fill up, so it had fuel to begin with. Once I added gas, it seemed to do OK, stuttering only once at about three grand (80 mph). Drove it again yesterday for another 25 mile drive, and it did fine. This time, I checked the cap, rotor, and wires again; plus looked for leaks and loose wires. Fuel filter is new. All good.
Oil pressure is normal. Water temp is in the center of the gauge. No leaks or loose wires/errant sparks. Vacuum is steady with no wobbling needle. In Park, I can bring the engine up to around 4,500 RPM without stutter or backfire.
All I can figure is that I had poor-quality fuel, and the added fresh fuel diluted that enough to make what was in the tank useable. Thoughts?
