Fuel
Ragman
2:08 AM
Glide, Oregon
Do you guys run non-ethanol fuel?
Are lead additives nescessary?
I have a 361 stock engine with 107K miles, 2barrel carb.
Thanx
Rag
Back in the day the lead in gasoline performed a couple of functions: It raised the octane rating somewhat, and it provided the added benefit of valve train lubrication. If valve guide wear is not an issue, and the car is not a daily driver, I would say what's currently available at the pump is ok. The ethanol added to todays gasoline can be troublesome for older vehicles as the fuel will absorb moisture easier and can thus corrode fuel sytem components. Hope this helps.
Actually, lead helped lube the valve and seat and not the valve train and yes, it helped raise octane rates. As for ethanol, it's an alcohol and is corrosive by itself and eats on the old style fuel rubber fuel lines and it's been only in the last 10 years or so that the OEM's have gone to a better material but the junk coming in from China is also a problem and is usually marked as being the better material. January Hot Rod did an article on fuel system plumbing and you should also be able to find info on the net. And if your engine is basically stock, it should run ok on unleaded fuels but if you use it in high load situations, then you may see your valves sinking and may want to install hardened seats in your heads. I've run all of my cars on unleaded gas for years and never had any problems but there are many that have had problems with sunk valves...
what is a sunk valve? a dropped valve?
A sunk valve means the valve pounds the seat away and the valve goes deeper into the head. Stock seats were not hardened until about the mid 70's and do not have that problem but a leaner condition can help the valve to burn sooner on unleaded with earlier engines.
I was in a hurry, yes, the "valve train" was not the right choice of words. However, the lubrication (or insulation) that the lead provided back in the day not only reduced wear with respect to the valve face & seat - as you describe -but it also helped reduce stem to guide friction, and thus guide wear.
Yes, ethanol is corrosive, but the good ol' fashioned H2O that it absorbs does not lend itself to a healthy fuel system either. The operative word here is "rust".
Yup, you're right about that! And it's not just rust that's a problem....it also attacks all components of the fuel system including all hose connections. The newer hose is a lot better but it still doesn't last as long as it would if there was no ethanol based fuels being used.
There are a bunch of issues being tossed around here.
Ethanol
Many (and ever more) of us don't have a choice to run straight gasoline any more; in more and more areas you can only buy gasoline that contains ethanol (or as many carburetor men call it, "deathanol"). It's not corrosive (that's methanol you're thinking of), but it does create problems by dint of carrying water through the system so parts that never saw much of any water on straight gasoline now are exposed to water fairly constantly. As others have mentioned, the big aggravator is sitting; this steeps the carburetor and other fuel system components in a brew that contains water, and corrosion is the result. This is why you see white "metal mould" corrosion when you open up a carburetor that's been running (and sitting) on gasoline that contains ethanol. There are plenty of additives marketed as preventing the damage. Does any of them work? Don't know. Sta-Bil makes one such additive and I use it when I have to leave my carbureted cars sitting for extended periods of time. I don't think there is an additive worth using on a continuous basis in an attempt to counteract the ethanol.
Ethanol is also deleterious to various soft parts -- various plastic and rubber materials. This is a pretty easy to manage issue: replace the fuel hose with fuel injection hose marked "30R9", which is proof against whatever flows through it and has much less permeability and much higher burst strength. It's expensive by the foot, but most cars don't need much of it -- a few short lengths in the engine compartment and one short length back at the fuel tank. Be sure and use the correct Fuel Injection hose clamps, which have rounded-off edges that won't dig or cut the hose. And use a fuel filter with a metal can, not plastic. I like the new-design carburetor inlet needle and seat supplied by www.daytonaparts.com (they come in their carb kits and they're available as individual parts, too).
Gasoline with ethanol causes and aggravates issues with cold starting, hot starting, and driveability. Slant-6ers can do the Fuel line mod; everyone can add a carburetor heat shield. Everyone who hasn't already got a vapour-bleed provision in the fuel line between pump and carb can also add a vapour-bleed fuel filter (NAPA Gold 3040, for example) and run the ¼" vapour line (proper fuel line hose and/or metal pipe, please, not just generic rubber tubing) all the way back to the rear of the car. It's usually a hassle to add the vent nipple at the back of the car. One of the easier ways is to remove the fuel gauge sender and add the vent fitting to its round plate. If you are working on a '70 California or '71 50-state/Canada car, you needn't go through the hassle and (manageable) danger of attaching a new tube to the fuel tank or sender, you can add the vapour line fitting to the top of the vapour separator in the trunk of the car; see here for detail on how the '71 (+'70 California) evaporative emission control system works. While you are reading up on it, take note that it will aggravate the hot start problems ethanol fuel creates, because fuel vapours accumulate in the crankcase after engine shutdown and flow freely into the intake tract (making the mixture too rich) as soon as you sit down and start cranking. You can eliminate this part of the problem by moving vapour storage from the crankcase to a '72+ type charcoal canister with a purge valve as described here.
Ethanol contains less energy than gasoline, so a gallon (or litre) of gasoline with ethanol contains less energy than the same amount of gasoline without. That means you get less work out of any given amount of fuel, which means reduced fuel economy and reduced maximum power.
Time was, ethanol was considered a contaminant in gasoline. Now that the ethanol industry has bought the best government money can buy, we're all supposed to learn to say "ethanol enhanced" gasoline instead.
Lead
With an unhardened exhaust valve and seat, the valve gets superheated by the exhaust flowing through it, then once the valve closes, it and the seat can micro-weld to each other. Lead halides act as a buffer (a physical "cushion" barrier) to prevent this happening. Then when the valve opens next, the metal pulls apart like taffy. This roughens the meeting surfaces, and they become quite abrasive. The pounding/turning of a valve with such "pulled" metal on it creates a nice grinding wheel effect on the seat, grinding it down so the valve sinks lower and lower. This is valve seat recession. In addition, the roughened surfaces no longer seal against each other properly, which eventually allows still-burning combustion gases to flow through the "closed" valve, causing a blowtorch effect on the poor valve and depriving it of any prayer of a chance to cool while it's on the seat. The blowtorch effect rapidly deteriorates the seal further, snowballing the seat recession.
This bad stuff happens only if the valve/seat junction reaches the critical temperature. Whether that happens depends on how the car is driven and used. Towing, drag racing or pedal-on-the-floor hauling will heat up the valves a lot hotter than driving down the highway at a constant 70 or hopping from traffic light to traffic light in the city or running down to the local grocery for a carton of ice cream. Additional factors in the margin of safety include the size of the exhaust valve, its material, and the efficiency of valve seat cooling in that particular engine design.
Very little lead is required to prevent the localised welding and taffy-pull-apart effect that leads to the abrasive surface which, through incidental or positive rotation of the valve, eventually grinds-down an unhardened seat. The majority of the lead was in the fuel as an octane booster, that's all. It was widely used because it was a very cheap and very effective octane booster. When unleaded fuels were first widely introduced, there was generally only one grade of unleaded available, and the octane was less than that of leaded regular.
We all know that when you use a fuel of insufficient octane, your engine pings (detonation, pinking, pinging, spark knock--call it what you will.) This creates tremendous heat in the combustion chamber--certainly enough heat to push the exhaust valves to the crucial temperature. Because for quite a while only unleaded fuel of subregular octane was available, plenty of people experienced these effects from using unleaded. While many of those engines that suffered under this low-octane unleaded really did need the lead (high load and/or high-RPM engines), the bulk of the failures were due to the low octane increasing combustion chamber temperatures.
These days we have wide availability of high-octane unleaded fuels -- remember, the pre-1972 octane numbers in the USA were higher for any given level of knock-resistance because in '72 the rating system changed.
if you have an old car that is a low-stress application , used in
daily-driver service, then you need have no qualms about using whichever octane grade of lead-free fuel your car runs well on and drive it for a long time with nary a valve or seat problem. Many US-based 6 and 8 cylinder engines fall into this category in normal daily driving service.
The way to eliminate even the possibility of valve heating causing localised welding and subsequent seat recession is to install hardened exhaust valve seat inserts and exhaust valves of upgraded material. This is utterly standard practice in the rebuilding of cylinder heads, and has been for years. It is foolhardy to rebuild a "leaded" cylinder head without these upgrades, which are not expensive. The factory's induction hardening is frequently not sufficiently deep to last through more than one regrind.
Of course, there's no reason to tear into the engine solely to install hard seats. There is no collateral damage from seat recession. Drive and enjoy until a problem develops, then address the problem.
"Lead substitutes" are largely useless. Some of them use a sodium salt and claim to duplicate the buffer effect of lead, but can't substantiate the claim. Some of them use MMT (methylcyclopentadienyl manganese tricarbonyl), which is highly toxic, is of highly questionable benefit in buffering exhaust valves. It also causes hard red deposits on your spark plugs that will cause you to need to replace them more often. Other additives are simply octane boosters of varying effectiveness and varying side effects (except on your wallet -- they cost a fortune!)
Methanol and ethanol contain soluble and insoluble contaminants.http://en.wikipedia.org/wiki/Alcohol_fuel#cite_note-4 Halide ions, which are soluble contaminants, such as chloride ions, have a large effect on the corrosivity of alcohol fuels. Halide ions increase corrosion in two ways: they chemically attack passivating oxide films on several metals causing pitting corrosion, and they increase the conductivity of the fuel. Increased electrical conductivity promotes electrical, galvanic and ordinary corrosion in the fuel system. Soluble contaminants such as aluminum hydroxide, itself a product of corrosion by halide ions, clogs the fuel system over time. To prevent corrosion the fuel system must be made of suitable materials, electrical wires must be properly insulated and the fuel level sensor must be of pulse and hold type (or similar). In addition, high quality alcohol should have a low concentration of contaminants and have a suitable corrosion inhibitor added.
Fantastic imformation to use in making my fuel decision.
My 361 engine has a compression of around 9:1 and I think I'll use the middle grade of of fuel and see how it runs. I'll use whatever grade avoids pinging.
Non-ethonol fuel is also available at about5 or 6 stations close by. It is rated at 92. Costs about $.70 a gallion more , but may be a good choice.
Thanx for all the input.
Rag
Excellent post Slantsixdan! And I couldn't agree more about calling it "deathanol". Since we have no control over this useless additive in our gas we will just have to live with it. Fuel injection, even a simple TBI setup, is really the only sure way to good drivability - but it isn't cheap - unless you go with the megasquirt kit system. The mods you describe sound good and could very well eliminate a lot of grief when running a carb.
I will add that ethanol can certainly be corrosive to aluminum. Surely not as bad as with methanol, but the issue shouldn't be ignored.
