Go to for steering box? Manual early b body
rpmmachineco
9:52 AM
North Carolina
I want to swap in a manual box from my power box while I'm in the middle of the K member swap. 63-Dodge 330. Should I be looking a "good" used on on ebay-swap meets, etc for a 62-64? Everything I see listed new is 65 on up? Sorry for asking something that's probably been asked a lot before..
The only difference is, the early cars used smaller mounting bolts than 1967 up cars. If you find a later box you should make some spacer bushings to fit the smaller bolts. The steering column is longer on manual steering cars.
The steering shaft is longer. Column is the same.
