steve from staten island
- 12:15 AM
- Sep 24, 2012
- staten island,ny
Yes, I know, as I stated initially. I was using an analogy. As we car guys use a central pump to feed our air tools, so they can implement a similar system for patients oxygen requirements.It's not Air it's Oxygen.
Thanks for the info. I am always interested to hear about how things work behind the scenes. Liquid o2 makes since. I thought they may use a o2 generator.A hospital oxygen source is a bulk liquid system with tanks that need to be filled. As long as the hood uses no more than a normal ventilator volume should not be a problem. All med gas systems are designed to operate every outlet. At most Hospitals there will be a set of tanks that frequently are ice covered and you will see vapor coming off especially in the summer.
Good point, but the estimate is we need way more than what we have. Where I live they are running low and we still are not near the peak. The next few weeks will be crucial.Every day I see more and more companies (all around the world) tooling to make ventilators. How many are too many? Not diminishing the good in this but seems out of control.
