Goodmark vs AMD Full Floor Pan
11:45 PM
Maryland
Is the AMD floor panel that much better of a fit and quality than the Goodmark? The price difference is nearly $200.00. Has anyone tried the Goodmark?
1971 Charger
I used a goodmark for my 70 charger and it did require some fitting. For body panels I only used AMD.
From the advertising of AMD, they come with all the holes and stuff pre-drilled. That should save time and headaches.
The AMD floorpan I just installed fit well and looks factory to me as does the AMD trunk pan I am about to install. The AMD trunk extensions do not fit, are short about 3-4 inches and will need modifications. I looked at Goodmark for everything I needed and didn't see much of an advantage cost-wise up here anyway, so I went with the general consensus of AMD being the best.
I've used Sherman for some other items and wished AMD was producing them as they are not very good, but I guess everyone knows that about Sherman. Better than nothing though...
It is a crap shoot there all made in China or Taiwan. Most everything I have used requires some sort of modification. And I have used everything out there. AMD is good Goodmark is good Sherman works too. Nothing is perfect but all can be used. Just depends on your expertise and the lot number.
Haven't used either of their floors but have used both brands, not impressed with Goodmark at all.
