- 10:50 AM
- Nov 22, 2010
- Muroc Dry Lake Bed
Copied from SAE International 18 november 2014
Flat Plane Crank:
"So named because its four connecting-rod journals are spaced 180° apart, the shaft appears “flat” in a single plane when viewed head-on. The arrangement generally does away with the large counterweights used in the typical 90° "cross plane" layout which helps reduce crankshaft mass and enables the engine to rev more freely. The new Ford spins to a heady 8000 rpm before fuel cut-off, according to Nair, and has another 250 rpm of safe headroom. This from mildly oversquare 94 x 92.7-mm bore and stroke"
Natural aspirated 750 HP
Rumored to be available in the 2015 Shelby GT 350 R
Flat Plane Crank:
