Has anyone taken a late model charger or challenger sunroof and fit it on a 68-70 "B" body?
Adam J Buff
New Member
2:06 AM
Panama City Florida
I am building a 70 charger resto mod and liked the thought of having a reliable retractable sunroof. knowing the original parts are pretty much impossible to find, and maintain, I was considering options and had the thought of using one from a junkyard late model charger challenger donor. Has anybody heard of this being a successful transplant? I'd like some input before I pursue having this done. Thanks in advance for any helpful input.
I happen to have one that I took out of an 06 Charger SRT-8 donor car. If you are interested I am looking to get $250.00 for it. It is complete with the harness , overhead console controls, 4 drain lines and if needed the headliner. I am in the Charlotte N.C. area if you can figure a way to get it. Shipping might be expensive. If you would just like more pictures or measurements just let me know. You have to be able to cut a clean hole in the roof that is about 1/2" inch smaller than the actual finished hole so you can bend over a lip to stiffen the hole. Also you will be cutting at least one cross roof brace and probably need to brace it front to rear with something you can attach the frame to. The only problem that there might be would be when it is closed it is tilted slightly forward to match the curve of the roof. You would have to position it so that when closed it matched the roof curvature.
