Head lights
Bvsbee
New Member
5:19 PM
canada
Just got my super bee in the shop and fixing all the lights the rear lights all work but can't get any power to the front lights. But the front marker lights do work. Any ideas. No power at dimmer switch either and fuses are all good
Lt. grn feeds the dimmer sw. from the hdlight sw.Make sure you've got 12v to hdlite sw and go from there. Per my manual all comes off dimmer switch.
Just as a by the way, has the car been upgraded with relays for the headlights at some point?
Both good Suggestions ^^^^^^^^ I'll just add to check your grounds but if there's no juice to the dimmer switch I'd start by checking voltage at the headlight switch as mentioned.
