Help help help power steering pump
Polara500426
2:47 PM
Lakewood,Ohio
Is there a replacement power steering pump Available on the market for my '64 Polara with a 426s ? Cardone is no longer an option and Specialty builds are in the $275.00 range. ANY $60.00 options out there? Rebuild kit is my last option only because I'm not certain its rebuildable.:laughing3:
This post needs to be moved to the correct catagory....You will find that most all that is needed is a good cleaning and new seals.Pretty easy to do.An auto part store with "Lend a tool" should have the pulley remover tool. If you can't find a seal "kit" be careful when removing the front seal,it should have numbers to match.Other than that, the housing "O" ring can be reused with a bit of RTV sealer on it.I've done 3 in the past all still working and no leaks.
