apostle228
Ok all, I am having an issue with the 318 in my Satellite... Yesterday, I replaced the spark plugs, cap, rotor, wires, reluctor and pickup in the distributor, as well as a new coil, ignition module, and voltage regulator.
Today, it starts right up... Better than it ever has. Idles very smooth, and I can rev it up with no issues, very smooth across the entire power band.
Then, I take it around the block... When it is under load, it sputters and hesitates, and even occasionally backfires through the intake. None of this happens when revving the engine in the driveway, it only happens when its under load and accelerating. Once I am up to speed and hold my speed, it stops hesitating and backfireing. Any ideas on what could be causing this? Where should I start on my troubleshooting?
