ykf7b0
I have a street/strip 69 roadrunner (434 hp at the rear wheels/ over 600 hp with nitrous) and I'm currently using a Fram canister type fuel filter with my Mallory 140 electric pump. I have experimented over the years with mounting locations of this filter and pump but I'm really limited because I do have the factory tank with a 3/8 pick-up in place. I recently removed my fuel delivery system from the inner passenger side frame rail and relocated it above the rear axle housing pinion because I was planning on installing tail pipes. This location is forcing me to prime the fuel filter after long periods of the car sitting and not being started. The Fram canister filter has the fuel inlet and outlet on top and the mounting configuration of the filter requires the fuel line from the tank to be much higher than the Mallory fuel pump. I feel if I install an inline filter and relocate the Mallory pump on the shock mount bracing in front of the factory tank the pull (strain) would be alot less than the current mounting location and maybe it wouldn't loose prime. I would like some recommendations for some good inline filters and/or if you think this is a solution to my problem. Thanks to all for a great web site!!!
