OCTAVIOUS
1970 Coronet R/T vert.
440 auto with Rallye Dash
Original charging system
Car was running good and the amp meter would run up to 20+ after start up and slowly head back to just above positive after a drive and do its normal thing
Few days ago the meter now goes up to 30 plus after a start up and now won’t return to below 15 amps i have tried to regulators both go to ~ 14v
Here is what I know…
1)The output from the alt terminal is what the amp gauge reads
2) volts from regulator above idle is 13.8-14v
3) battery reads 12.7v at rest and follows voltage reg in running condition.
4) drove for 45 minutes still doesn’t drop below 17amps where it use to go down to 3-4amps
5) connections from everything in the engine compartment has been pulled and cleaned including bulkhead connections.
6)at a stop light it will drop to negative on the amp meter
Suggestions
Suggestions
