How to begin removing the guts from a door?
Dibbons
8:30 AM
La Paz, B.C.S., Mexico
Need to paint my 1972 Satellite Sebring Plus doors. Do I remove the glass first or will the glass come out better/easier if I remove the glass along with the window crank mechanism? Thank you.
Glass first, then mechanism. If its anything like a 73, You should have some access holes that line up with the studs that hold the glass to the mechanism. just roll up or down until they line up to give you access, unscrew them, and remove the glass. Then you can tackle removing all the bolts that hold the mechanism to the door, don't for get to get the ones on the underside of the door, and also the rubber stops at the bottom of the door.
