huge list of charger,68-9-70 roadrunner, 69-66coronet 66-7 charger ect.
joel
3:38 PM
edinboro pa
Feedback: +20 / =0 / -0
b-BODY BODY PARTS
e mail
68 charger doors fair cond some seam rust no rot through 125.oo ea with glass, clear,
69-70 charger doors various conditions 50-125.oo
66-67 coronet trunklid some small seam rust 100.oo
69 coronet flat hood excellent cond [make your own ramcharger] 200.oo
66-7 coronet left fender fair cond rust in very lower dog leg driver qual. 50.oo
69 roadrunner ,gtx front fender no rust has large dents 75.oo ea . left and right
68-70 charger trunklid large seam rust 25.oo
63 dodge trnklid good cond 125.oo
63 dodge hood exc 100.oo
located in n.w. penn NO SHIPPING on body parts
parting out 68/69 roadrunner /satellite/gtx
rear core seats50.oo ea
points distributor 383/400 75.oo
k frame 100.oo
lower control arms for sway 125.oo
sway bar 50.oo
tailights 25.oo ea
tailight housings 25.oo
tailight surrounds 25.oo ea
headliner bows 50.oo set
dash parts green , gl. box door 50.oo
under guages pad non a.c. black , green , blue 50.oo
guage cluster with factory clock 125.oo
wiring harness 100.oo
dash vents 25.oo ea
rear window trim 150.oo
front window stainless 100.oo
68 plymouth stainless dog dish hubcaps excellent 150.oo--4
69 roadrunner/gtx parts
a pillar plastic trim typical attaching pc. broken black 25.oo ea
69 roadrunner tailight lenses nice driver or polish for show qual 25.oo ea
69 roadrunner tailighjt chrome bezels some pitting 25.oo ea
68 roadrunner tailight lenses 25.oo ea
68 roadrunner tailight chrome bezels some pitting 25.oo ea
bumper brackets front 25.oo ea
69 rr/satt headlight bezels 25.oo ea
hardtop door glass non tint 50.oo ea
hardtop qtr glass non tint 50.oo ea
door window regulators 25.oo ea
qtr window regulators 25.oo ea
post coupe qtr glass non tint 100.oo ea
post coupe post stainless 100.oo pr
post coupe inner headliner steel headliner support trim 25.oo ea
post coupe interior qtr panel steel upper door panels 25.oo ea
post coupe door seal stainless 50.oo ea
hardtop rear upper door panels steel 25.oo ea
vent window frames some pitting 25.oo ea
vent window rubber seal 5.oo ea
vent window glass 20.oo ea
69 roadrunner tailights with bezels small pitts , fair cond 25.oo ea
69 rr/gtx tailightqtr. extensions 25.oo ea
black int. parts
heater box non a.c. 100.oo
vent box for driver side 25.oo
69 b-body roof cut oversize cant ship 100.oo -175.oo
rear window 150.oo
front windshield stainless trim 100.oo-set
rear window stainless trim 100.oo set
vinal roof trim 100.oo plymouth or dodge 68-70
dual exhaust hanger ( bolts to bottom of body 20.oo
headlight retainer rings 5.oo ea
dash switch panel with switches 100.oo
sidemarker assemblys with reflector and retaining plate 25.oo ea
glove bod lid black,blue .green 50.oo ea
heater control [non a.c. ]50.oo
steering column filler pc[under col]black ,,25.oo
69 gtx tailight lense 50.oo ea
69 gtx tailight bezel pitted 50.oo ea
69 gtx rear finish panel pitted 150.oo
wiper arms 20.oo ea
inside mirror 20.oo
manual steering box 100.oo
8 3/4 rear axle housing and axles 125.oo
14x5.5h magnum 500 wheels [road wheels ]need restored 20.oo ea
10 inch rear drum parking brake parts 20.oo
11 inch rear parking brake parts 20.oo
70 rallye dash frame 200.oo
70 rallye dash cluster from 70 roadrunner missing tach 250.oo
heater vents black 25.oo ea
heater hoses [non a.c. ]
68 rallye dash harness 250.oo
69rallye dash wiring harness 250.oo good cond
69 CHARGER /superbee RALLYE DASH parts
68-9 rallye dash frame with 3 speaker cutouts 150.oo
69 CHARGER /superbee RALLYE DASH frame poor cond 100.oo
green padded part under rallye guage cluster right side 50.oo
green padded part on left below rallye guages 50.o
blue glove box door needs redye 50.oo
blue padded part under rallye cluster non a.c.for rallye dash needs redye 50.oo
ASHTRAY[COMPLETE ] 25.OO
DEFROST VENTS 20.OO EA NOT BROKEN BLACK
727 small block trans 125.oo
727 big block trans 125.oo
70 coronet R/T 500--parts
coronet 500 dash pcs, inquire
hood saftey catch assy 25.oo
70 coronet 500 chrome qtr panel insert chrome fair cond 40.oo pr
rear qtr extensions 30.oo ea
70 roadrunner parts --------------------------------------------------
grille =poor cond 25.oo
grille broken tabs and a couple of grille bars missing 10.oo
lower grille plastic (part between bumper and grille) 75.oo
filler piece between bump. and grille (steel) 50.oo
70 383 H.P. motor/ not running/ missing = valve covers/carb/exh manifolds/400.oodated 10 of 69
k-frame 100.oo
lower control need sand blasted 125.oo pr
power steering box 50.oo
8 3/4 rear axle housing + axles 125.oo
door glass for hardtop tint 75.oo ea
door glass for hardtop non tint some scratches 50.oo e a
qtr panel hardtop glass non tint 50.oo ea
rear glass 150.oo
4 SPEED
66-9 4 speed transmission 350-.oo
11 inch cast iron bellhousing 350.oo
70-71 alum. bellhousing 383-400-440--. craced and has bee rewelded 125.oo
66-67 b body 4 speed pedals with spring 250.oo nice cond
68-70 b body 4 speed pedals nice cond no spring 200.oo
68-69 b body steering column 4 speed /floor shift power steering 200.oo
68-69 b body steering col. 4 speed /floor shift / had extension welded on to make it a manual steering col. 150.oo
DANA 60 b body 66-70 4.56 gears nice orig. 1500.oo
8 3/4 66-70 b body axles/housing + axles 125.oo
b body axles only pr -50.oo
11" backing plates 50.oopr
10 " backing plates 25.oo
10 " backing plates =complete 50.oo
67 BELVEDERE II, parting out
,nice grille 100.oo
rear finish panel small dent 50.oo
,dash parts---inquire
belvedere II glove box door 25.oo
8 3/4 rear axle no center 125.oo
-all door glass non tint 50.oo
ea
ply full wheel covers for 14 inch 25.oo-set of 4 much much more
66 coronet 440 2 door hardtop a.c. car
trunklid -- some seam rust very usable 75.oo
roof cut oversize rust free 100.oo[ pickup only]
front door regulators 25.ooea
a.c. dash parts,
heater controls 25.oo
drivers side vent box with cable 35.oo
lower control arms no sway bar mounts 50.oo pr
lower control arms with sway bar mounts 125.oopr
power steering box 25.oo
bench seat 100.oo
rear seatr cores 50.oo pr
tailight chrome bezels 25.oo ea
tailight alum surround trim 25.oo ea
tailight wiring harness 25.oo
top of door stainless pc 20.oo ea
67 440 h.p. exhaust manifolds 450.oo pr
1966 DODGE CHARGER parting complete car
bucket seats - no tracks , no seat backs 100.oo pr
door panels black 250.oo-set of 4
full length console 250.oo
console brackets 100.oo-all
console lights 50.oo pr
console wiring 25.oo
console padded rear armrest 25.oo
console padded top 50.oo
headliner 50.oo
guage cluster bezel and guages factory tach 250.oo
dash wiring 150.oo
radio 50.oo
radio/heater control bezel uncut 50.oo
rear seats , no rips 100.oo pr
seat belt set for bucket seats black poor cond 50.oo
66woodgrain steering wheel one 1/4 inch crack 100.oo
wood grain wheel horn button 25.oo
floor shift steering column 200.oo
under column, cover black 25.oo
c pillar sail panel covers black 100.oo pr
door glass 50.oo ea
qtr glass 75.oo ea
regulators 25.ooea
rear window glass 150.oo
front windshield trim 125.oo
wheel opening mouldings 50.oo ea
hood front trim has dent 50.oo
lower grille trim exc. 100.oo
grille assy completewith hideaway headlights and motors cond. unknown, 350.oo
headlight wiring 75.oo
drip rail stainless 75.oo ea
qtr window oustside stainless 75.oo ea
trunklid emblem decent cond hazing of chrome 25.oo
sway bar 100.oo with mounts
lower control arms with swaybar mounts 125.oo pr
bumpers 50.oo ea cores
bumper brackets 50.oo pr
much much more
i will ship most parts
personal message me for details and pics
"front and rear chrome" do you mean windshield chrome . personal message me , for ?s
68 charger-looking for a clean rear glass,upper stainless windshield moulding(the long one),small drip rail 45 degree moulding,right lower rear glass moulding(radius 90 degree one) thanks mac.
i have the upper windshield molding and the drip rail 45 pc , pm me for specifics ,, joel
i found every thing but the back glass locally, but thx for the message.
