Anybody with Hyundai experience here? I will try to explain this as best I can.
I used to think my Veracruz (08) had a dragging starter. On occasions after starting I get this loud horrific screeching noise. This has been getting worse progressively. Sometimes it would stop in short order, other times if I would back the key off just a hair it would stop. As time went on I would get the same noise at times when shifting from D to N to R to P.... but ONLY in the N & P positions.
This happened last evening when I parked at home after work. So to stop the noise (and grinding my starter??) I shut it off in D. Granted I can not shift to P with the switch in the off position. So I put the key in the "on" position. Not "start" but just "on"........... but she started anyway. Tried it again to make sure of what I was doing and got the same result.
Do I need a new ignition switch?
And if so. does the ecm/pcm need to be replaced along with it. I've had Toyotas in the past where you couldn't swap one without the other.
BIGS
BIGS
I would think if I can use my original key and tumbled noo reprogramming would be required. (??????? :dunno: ) Lord only knows what my starter drive and flywheel are looking like.
